Parts Mac MacBook Air 13" 2017 Hard Drives (SATA)
Store
Don't know your model? ID Your Mac
MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.
From $79.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
From $149.99
MacBook Air 13" (Mid 2013-2017) I/O Board
Replace a damaged or corroded I/O board for your Mid 2013 to 2017 MacBook Air 13" and fix problems with charging, audio, and data connections. This assembly includes the ...
$79.99
MacBook Air 13" (Mid 2013-2017) Display Assembly
Replace your cracked, dark, or dead-pixel infested display assembly of your MacBook Air. This 1440x900 LCD, 13.3" screen is complete with aluminum case and camera.
From $379.99
MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Replace a torn or damaged cable connecting the trackpad to the logic board in a Mid 2013 to 2017 13" MacBook Air.
$14.99
MacBook Air 13" (Late 2010-2017) Fan
Replace a defective or noisy fan compatible with a Late 2010 to 2017 MacBook Air 13" laptop with this part.
From $6.99
MacBook Air 13" (Late 2010-2017) Lower Case Screw Set
Replace missing screws in the lower case of your laptop. This set is compatible with a Late 2010 to 2017 MacBook Air 13" laptop.
$19.99
MacBook Air 13" (Mid 2013-2017) Upper Case with Keyboard
Replace a badly damaged upper case or keyboard of your Mid 2013 to 2017 MacBook Air 13" with this part. This assembly includes the keyboard, palm rest area, and power but...
From $49.99
Showing products 1 - 10 of 22
Device Info
Apple released the updated 13" MacBook Air on June 5, 2017. The model number, A1466, remains the same as previous years, but internally the Air gets Intel's newer Broadwell ULT dual-core processor, and a slight boost in battery life thanks to that chip's increased efficiency.
