MacBook Air 11" (Mid 2013-Early 2015) I/O Board
  • MacBook Air 11" (Mid 2013-Early 2015) I/O Board
  • 360°
360
Condition: Used
$99.99
$99.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
  • Replace a damaged or corroded I/O board for your Mid 2013 to Early 2015 MacBook Air 11" and fix problems with charging, audio, and data connections. This assembly includes the MagSafe 2 power, USB, and audio ports.
Compatibility
Repair Stories
Daniel's Story Photo #1361750
My Problem
Part of a headphone jack was stuck inside the headphone port.
My Fix
I ordered a replacement I/O board. Removal and installation was simple.
My Advice
There's a hole on the backside of the headphone port. If there's no physical damage, simply removing the I/O Board and using a small pin allows for removal of any stuck . . .
My Problem
My MacBook Air stopped taking charge and died. The charger connector stopped lighting up (neither green nor amber) The charger is good as it works fine with my other MacBook Air. So, I suspected a bad I/O board.
My Fix
I ordered a new I/O board and followed the iFixit instructions to replace it. But, unfort . . .
My Problem
After putting a flash drive into my USB port upside down, I quickly realized that the port was done. No big deal, I thought; I have one more. A few days later, I realized that my Macbook Air couldn't play sound. I did some research, learned about the I/O board and figured that I probably messed up w . . .
