Parts Mac MacBook Air 11" Late 2010 Heat Sinks
Store
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Air Plastic Feet
Replace the black plastic feet on the lower case of your laptop. These feet are compatible with most 11" or 13" MacBook Air laptops.
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
From $39.99
MacBook Air 11" (Late 2010) Replacement Battery / Fix Kit
Replace the 4790 mAh, 35 Watt Hour battery in your MacBook Air 11" (2010).
From $69.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
Macbook Air 11" and 13" (Late 2010-Mid 2011) SSD
Replace or upgrade the SSD in your MacBook Air.
From $59.99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7.99
MacBook Air (Late 2010-Mid 2012) AirPort/Bluetooth Board
Fix wireless connectivity issues by replacing the 802.11n AirPort wireless / Bluetooth 2.1 internal card in your Late 2010/Mid 2011/Mid 2012 MacBook Air.
$29.99
Showing products 1 - 10 of 30
Device Info
On October of 2010, Apple introduced a smaller and even more portable MacBook Air with the 11" model. The new Air features a flash memory module instead of a conventional hard drive, and the battery dominates most of the internal space. This lack of conventional hard drive allows the machine to be insanely thin.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
