Parts Mac MacBook 13" (Model A1181) USB Boards
Store
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
From $89.99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
MacBook Replacement Battery / White / New
Replace your dying or broken battery with this replacement. Compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). 4900-5200 mAh, 55 Watt Hours (...
From $64.99
1 TB 5400 RPM 2.5" Hard Drive / Toshiba
Replace or upgrade the hard drive in your compatible MacBook, MacBook Pro, Intel Mac mini, and Sony PS3/PS3 Slim/PS4 game consoles.
$74.99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
$54.99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7.99
PC2-5300 2 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 200 pin / DDR-2 / 667 MHz
$14.99
Showing products 1 - 10 of 112
Device Info
All older MacBooks have the same A1181 model number. However, not all parts are compatible with every machine. Be sure to ID your Mac to ensure correct selection of your model above!
With the exception of the Mid 2009 model, all plastic MacBooks use PC2-5300 RAM, available in our parts store.
These machines are notorious for pieces of the upper case breaking off near the trackpad. Fortunately, it's easy to fix-- just use our repair guides to replace the upper case! Select your machine above to make sure you buy the right case component.
