512 GB SSD
512 GB SSD
Not for sale
Not for sale
Product Details
Features
Features
Sandisk X400 Model #: SD8SB8U-512G-1122
  • Super fast, SanDisk's top of the line X400 512 GB SSD.
  • Hard Drive enclosure used for transferring your files also converts your old drive into a handy external USB drive.
  • Don't get caught with the wrong equipment this kit has everything it takes to get into most laptops.
  • Use the free SuperDuper! to transfer your files with the enclosure.
To upgrade a 2010 or later Intel Mac mini you will need a Mac Mini Logic Board Removal Tool in addition to the tools in the kit.
Kit Contents:
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7, Late 2012)
2.5 GHz (Dual i5, Late 2012)
2.6 GHz (Quad i7, Late 2012)
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
Mac mini Model A1176
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
Mac mini Model A1283
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
MacBook Pro 13" Unibody Mid 2009
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
MacBook Pro 13" Unibody Mid 2010
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
MacBook Pro 15" Unibody Mid 2009
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
MacBook Pro 15" Unibody Mid 2010
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
MacBook Pro 17" Unibody
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
MacBook Unibody Model A1278
2 GHz (A1278)
2.4 GHz (A1278)
MacBook Unibody Model A1342
2.26 GHz (A1342)
2.4 GHz (A1342)
Show 25 more devices
Repair Stories
User avatar
My Problem
I had a fairly outdated laptop and decided that replacing the battery and the hard drive would be cheaper than buying an expensive new computer that I wasn't likely to use to its full capacity anyway.
My Fix
Both repairs were easy enough to do using the instructions on here. There was a bit extra I had to . . .
User avatar
My Problem
I am the office administrator for a small 5 staff non-profit. My boss' 2011 MBP had a bad RAM stick and an old HDD. I recommended to max out the RAM, put in a new SSD, and install Yosemite.
My Fix
Very very very easy. I kinda wish it took longer with more steps, I was enjoying the process so much. Having th . . .
User avatar
My Problem
Replace logic board; replace HDD with SSD; move HDD to optical bay; upgrade RAM.
My Fix
All in all, everything went well. Considering that this was my first repair ever, it took me much longer (4-6 hours) than indicated (40-60 mins). Also, during the repair I had to watch a couple of video tutorials on YouT . . .
User avatar
My Problem
My original Hard Disk was almost full and slow for Mac OS Yosmeti. So I replaced for a SSD Hard Disk.
My Fix
I used the repair guide and video from www.ifixit.com. The experience was very good. I had no problems in doing my self the replace. Now my Macbook Pro is very fast.
My Advice
For those who has a Macbook Pro an . . .
User avatar
My Problem
My Mac Mini 2011 lately got slower and slower and I considered even buying a new one. But when I discovered that the core hardware from my mac mini even with a beefed up new mac mini would not be essential different, I reconsidered and looked more into the why my mac mini is slow. Turned out that i . . .
User avatar
My Problem
My mid-2010 Macbook Pro was constantly lagging! I couldn't click an application without minutes of thr dreaded beach ball!
My Fix
I ordered the new SSD from iFixIt and it arrived earlier than expected. The repair was ridiculously simple and I can't believe that people pay hundreds of dollars to have Apple d . . .
User avatar
My Problem
Late 2012 MacBook Pro had slowed down to a crawl. It had an i7 processor, but the 5400 rpm HDD could not keep up after years of use. The new SDD drive has made a huge difference in performance. Even with Sierra installed it works great. I would definitely recommend it.
My Fix
It was easy if you follow the . . .
User avatar
My Problem
Wanted more storage space: added 1TB Drive and 1 512 SSD
My Fix
Easier than I thought it would go.
My Advice
Need to explain that if you're installing a 2nd drive, one drive mounts in the grommets in the kit and one drive sits on top with the ribbon in between but DOES NOT HAVE MOUNTS other than the screws from the an . . .
User avatar
User avatar
Show more
