500 GB SSD Hybrid 2.5" Hard Drive
  • 500 GB SSD Hybrid 2.5" Hard Drive / New / Part Only
  • 500 GB SSD Hybrid 2.5" Hard Drive / New / Upgrade Bundle
Seagate
Model #: ST500LX025
$74.99
$74.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Hybrid technology from Seagate combines SSD and traditional hard drive technology to provide SSD speeds from an affordable high capacity hard drive. Adaptive Memory technology keeps the files and file types you access the most ready and available for instant transfer from SSD.
No software or operating system requirements, Adaptive Memory technology is self-contained and works like any SATA drive.
Note
To upgrade a 2010 or later Intel Mac mini you will need a Mac Mini Logic Board Removal Tool in addition to the tools in the kit.
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
Mac Mini Late 2014
1.4 GHz (Dual i5)
2.6 GHz (Dual i5)
2.8 GHz (Dual i5)
3.0 GHz (Dual i7)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
Mac Mini Model A1176
1.5 GHz (Core Solo)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo)
Mac Mini Model A1283
2 GHz (Core 2 Duo)
2.26 GHz
2.53 GHz
2.66 GHz
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Core 2 Duo Model A1211
2.16 GHz
2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz
2 GHz
2.16 GHz
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.33 GHz (Core 2 Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.53 GHz (Mid 2010)
2.66 GHz (Early 2009)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
MacBook Unibody Model A1278
2 GHz
2.4 GHz
MacBook Unibody Model A1342
2.26 GHz
2.4 GHz
PlayStation 3
CECHA
CECHB
CECHC
CECHE
CECHG
CECHH
CECHJ
CECHK
CECHL
CECHM
CECHP
CECHQ
PlayStation 3 Slim
CECH-20xx
CECH-21xx
CECH-25xx
PlayStation 4
CUH-10XXA
CUH-11XXA
Show 27 more devices
Repair Stories
Richard Urrutia's Story Photo #876745
Richard Urrutia's Story Photo #876742
Richard Urrutia's Story Photo #876740
My Problem
I replace the battery. Then the "flashing Question Mark and Folder" I did some research and decided to try a new Hard Drive Cable, since it has been known to fail. Still the flashing question mark and now desktop Hard Drive image. Tried "restore" and couldn't find the hard drive. Next step "new . . .
My Problem
The original SATA hard drive was becoming unstable and failing.
My Fix
The new SSD drive arrived right on time. I must say the price was great, Thank you. I had watched a video online and the installation was a breeze.
My Advice
Remember to have the correct torx size to remove and install the mounting tabs from the o . . .
My Problem
My friend's well used MacBook Unibody was beginning to run very slowly and unpredictably, so I assumed, based on experience, that the hard drive was dying. Being inside, we upgraded the memory as well.
My Fix
Easy to do. The repair guides for RAM and Hard drive made it easy. Also decided to remove and reins . . .
My Problem
The old hard drive that came with the MacBook Pro died completely.
My Fix
The replacement of the hardware went well and worked per the instructions but loading OS X was much trickier and time consuming than I expected.
My Advice
The replacement ssd comes with a case to allow it to connect via usb. If you have another . . .
My Problem
Laptop suddenly stopped charging. Was coping for a while with a track pad that wouldn't drag and drop or click and select ranges. So decide to fix the latter while trying to bring my MBP back to life. Also decided to do it myself as official service estimate in India was 2x the part cost (HDD). iFix . . .
My Problem
The original HD in my wife's macbook pro died. Replaced it with a 500G SSD, and put in a new battery while I was at it. The replacement probably took 15 minutes. Formatting the SSD in an external housing, and loading it with the backup software took far longer.
My Fix
Just fine. Already had a full . . .
My Problem
Replace HDD in MacBok Pro
My Fix
Simple. Just followed easy directions .
My Advice
Suggest easier way to get in contact with a real person.
My Problem
my HD was damaged...
My Fix
just clone the HD and install it, simple as that.
My Advice
do it yourself is great, repair is possible and cheap.
My Problem
Computer very slow and old.
My Fix
It was a breeze to install.
My Advice
Good choice.
My Problem
I was running out of space on my 250gb drive constantly and didn't want to have an external drive connected to my laptop.
My Fix
The replacement guide was great, very easy and straightforward. However, there was no guidance on how to migrate your existing data from your existing drive to the new drive. A . . .
Show more
