128 GB SSD
$94.95
Product code: IF107-123
128 GB SSD
$94.95
Product Overview
A 128 GB Solid State Drive with the tools needed to swap it in.
  • Super fast, SanDisk's top of the line X400 128 GB SSD.
  • Hard Drive enclosure used for transferring your files also converts your old drive into a handy external USB drive.
  • Don't get caught with the wrong equipment this kit has everything it takes to get into most laptops.
  • Use the free SuperDuper! to transfer your files with the enclosure.
To upgrade a 2010 or later Intel Mac mini you will need a Mac Mini Logic Board Removal Tool in addition to the tools in the kit.
Kit Contents:
Compatibility
  • All MacBooks and MacBook Pros (excluding MacBook Air and MacBook Pro Retina)
  • All Intel Mac minis
Product Details
  • Interface: SATA 6.0 Gb/s
  • Dimensions: 2.5" (69.85mm) wide x .27" (7mm) tall
  • Capacity: 128 GB Unformatted
  • Read: Up to 540 Mb/s
  • Write: Up to 340 Mb/s
$94.95 Upgrade Kit
Condition:
New
Notes:
This option contains the drive and kit components.
$79.95 Drive only
Condition:
New
Notes:
SanDisk X400
Model #: SD8SB8U-128G-1122
Add to Cart
Replacement Guides
Mac Mini Late 2012
Difficulty: Moderate
Mac Mini Mid 2010
Mac Mini Mid 2011
Mac mini Model A1176
Mac mini Model A1283
MacBook Core 2 Duo
Difficulty: Easy
MacBook Core Duo
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
Difficulty: Easy
MacBook Unibody Model A1342
PlayStation 3
PlayStation 3 Slim
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7, Late 2012)
2.5 GHz (Dual i5, Late 2012)
2.6 GHz (Quad i7, Late 2012)
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2 GHz (A1278)
2.4 GHz (A1278)
2.26 GHz (A1342)
2.4 GHz (A1342)
Stories
My Problem
My 2010 Macbook Pro started giving me problems about three months ago, it got really really slow (consistently froze up for about seven seconds after anything, even a simple click!) and then it wouldn't turn restart. Pulling out my handy 2008 Macbook (my beloved relic of a computer which, surprisingly still works fine) I troubleshot and determined it was a hard drive failure.
My Fix
The repair went smoothly. I ordered both the 128GB hard drive (I don't use that much memory) and the tool kit, which included every single screwdriver bit that I required. The step-by-step instructions went without a hitch, and when I hit the power button it worked like a charm. ifixit is the tops!
My Advice
Advice: This is a very simple repair which, if diagnosed correctly, will whisk away your worries. Buy the toolkit, because Apple obviously likes to make it difficult for plebeian society (us) to work on their products so they use all the odd screw heads; so unless you have a tri-wing screwdriver and a set of torx lying around, get the toolkit.
My Problem
My wife's MacBookPro was becoming ever more sluggish. I had seen this before: the last time it happened, a hard drive had a catastrophic failure and data was lost. I decided it was time to banish moving parts from her computer forever. SSD, here I come!
My Fix
The hardest part was getting the drive set up -- it took about an hour to download OS X, and another half hour or so to set up the drive and install. I used the provided usb adapter and enclosure to install it directly to the new disk, and then swapped the old disk out. The swap itself took a whopping 15 minutes! The provided toolkit was impressive -- it and the enclosure together cost a meagre $20, and it was money well spent. I can't comment on its long-term sturdiness yet, but it looks very promising.
The end result? My wife's computer performs 50% faster (at least subjectively, because of load times) and suddenly has 150% of its former battery life. I think I just added another 2 years to that computer's lifespan.
My Advice
I had no idea how simple it would be. Be not afraid!
But do look up how to install OS X onto an external drive. That's actually the hardest part, easy as it is.
My Problem
My original HDD in my 2010 MacBook Pro died so I needed to get this issue fixed so I could continue with my school work.
My Fix
The repair was super easy to do. It took me about 5-10 minutes from start to finish and it was just a matter of popping the old HDD out and transferring the screws to my new SSD.
My Advice
If you have the opportunity to upgrade to a SSD, I would recommend doing so!
My Problem
I was gonna upgrade the Mountain Lion to the latest OSX, which has new features such as Facetime audio. However, it's really hard for the 2012 13" Macbook Pro to run the new systems with an HDD(actually it also performed poorly on Mountain Lion). Hence, I decided to get rid of the CD-ROM and replace it by an SSD.
My Fix
It took me 30 minutes to finish the replacement of SSD (didn't change the HDD from the original place).
The process by iFixit is quite enough but not so perfect. I've searched for some other websites which include much more pictures for each details.
If iFixit would have more pictures, I might be able to finish it within 15 minutes.
My Advice
Wearing a glove would be better.
My Problem
There is nothing wrong with the computer except its speed. It needed much more memory to handle the new Mac OS software, Microsoft Office and Turbo Tax. It would take almost 5 minutes for the computer to just boot up getting ready to be productive.
My Fix
I up graded to 8 Gig of ram, a really easy install. Then I put in the 128 Gig new SSD drive and used Super Duper to clone my original hard disc. Worked like a charm and now I am off to the races for the first time in years.
My Advice
I took the old disk out before cloning the new one. Put the replacement disc in, the plugged in the old hard drive, booted the computer off the old disc and did the Super Duper. Worked like a charm. The video and tutorials made this an undaunting task. I don't usually tear my electronic gear apart like this. Thanks for the confidence to do this.
My Problem
Bought a MacBook Pro early 2011, but getting slow with all the updates and software.
My Fix
Changed the 2 x 2GB RAM Chip into 2 x 4 GB Ram Chip,
Made a FusionDrive - The 500GB HDD and the 128GB SSD made together the MacBook Pro 3 times faster...
in Allignment with a Clean install of OS X I have new computer for peanuts.
My Advice
know how to make the fusion drive, ask advise and if you have questions.. => internet
My Problem
No problem, just little slow
My Fix
It went well
My Advice
It's easy, just do it your self and save some money. Here (finland) they took 89€ from that work.
My Problem
Constant beach ball. Simple tasks painfully slow to execute.
My Fix
Swimmingly. Opened it up, dropped in the goods (solid state drive, new RAM, new battery), and boom! Back in action. I had a few hiccups installing Yosemite from USB drive, which were quickly countered with the moves shown below.
My Advice
Before installing OS X, you will probably need to format your drive to GUID (http://osxdaily.com/2014/10/16/make-os-x...).
If you get an error message installing OS X (in my case Yosemite) for no apparent reason, you may need to set the time through terminal (https://www.youtube.com/watch?v=rvd1D129...).
My Problem
The SMART status of the old hard disk failed.
My Fix
Got the Solid State drive with the installation kit. Unfortunately, none of the supplied bits worked for the Unibody's screws. I had, however, an eye-glass repair kit with the tiny screw drivers that you need.
The sleeve with the USB connector was fabulous as I could migrate the system from the old device.
My Advice
As always, the fixit website's instructions and the figures were marvelous.
I would suggest you add to the screw-bits kit an instruction which bit to use for what screws.
It may also be useful to add for disk purchases instructions of how to migrate a boot disk onto the new disk. I used this youtube video http://www.youtube.com/watch?v=onorIa2b5.... Although clunky, the steps worked exactly as described.
My Problem
Hard drive was failing, and had to replace so I decided to go with a solid state drive.
My Fix
Easy, the guides made it go flawless. At first I thought it would very difficult and even thought to take it to a repair place. iFix it saved me money and in the process I learned something new.
My Advice
Keep screws together, or else you are going to have lots of trouble trying to find them. Also don't screw them all the way in, because I broke part of my screwdriver that came in with my kit.
