12.7 mm SATA 8x SuperDrive
  • 12.7 mm SATA 8x SuperDrive
Condition: Used
$49.99
$49.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
This dual-layer SATA drive does not include the metal mounting bracket and the orange ribbon cable.
Compatibility
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Model A1283
2 GHz (Core 2 Duo)
2.26 GHz
2.53 GHz
2.66 GHz
Show 4 more devices
Repair Stories
User avatar
paulchernoff's Story Photo #177310
My Problem
The optical drive needed replacing. As long as I had the Mac mini opened I decided to also upgrade the hard disk.
My Fix
To my shock everything worked once I was done and there weren't any screws left over. It was nerve wracking, the Mac mini isn't designed for home repairs. If I knew beforehand how difficu . . .
User avatar
My Problem
Optical drive was going out, only reading discs half the time.
My Fix
Very smoothly, much easier than I had anticipated.
My Advice
Everything is pretty straightforward once you get the outer case off and start digging around inside. Just make sure you keep track of all the parts and be very careful when removing the . . .
User avatar
My Problem
My Optical drive would not read a CD and it made a horrible noise. I used the guide and opened the case to find a few of the tiny gears from the original drive had fallen out. It was obvious that one of my children had tried to insert more than one CD in the drive.
My Fix
I ordered a used drive, used the gu . . .
