My Problem
CD player broken.
My Fix
I followed the instructions online and it worked flawlessly!
My Advice
Not hard to do if you check the instruction videos.
Cancel
Product Details
Features
You can now have two hard drives in your laptop! By replacing your optical drive, you can install up to a 1 TB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Optical Bay is 12.7 mm tall. Accepts 2.5 inch SATA hard drives up to 9.5 mm in height.
Note: This enclosure does not work with ATA drives or drives taller than 9.5mm.
Compatibility
Show 3 more devices
Replacement Guides
Difficulty:
Moderate
Difficulty:
Moderate
Difficulty:
Moderate
Difficulty:
Moderate
Difficulty:
Moderate
Repair Stories
CD player broken.
Optical drive on macmini a1176 wouldn't give up the discs anymore. Found the solution on iFixit which was to drop in a hard drive using their caddy/enclosure and a 2.5" drive I had already.
Very smooth and most importantly, it worked the FIRST time. It helps if you've opened older mac minis before an . . .
Broken optical drive on my old machine I don't have the heart to replace with a flashy new model, libraries are wayyy too big for the 160gb original HD and don't use compact disks too often anymore, so decided to add a TB
so easy! Doesn't even screw in just sits right where optical drive was.
Remembe . . .
This is a project that was kind of dumb to get into. Tearing apart an
old iMac I only use to run my scanner because the optical drive was
croaked and i wanted to change the boot to SSD. Once you have a computer that boots up quickly you get spoiled.
it was a lot more work than I anticipated. But your . . .
Running Yosemite, my early 2008 iMac had been reduced to a crawl. It would take minutes to boot and even wake from sleep. Mail took forever to load. iPhoto took even longer. Every app spawned spinning beachballs that seemed to never go away. Streaming audio would too often just stop for no reason. M . . .
Received a 24" 2008 iMac (2GB RAM, 2.8 duo-core) hand-me-down that had potential, but was slow and had a smaller internal HDD. I'm unfamiliar with Mac's, but I also had an unused 120GB SSD laying around and figured I would tinker to learn Mac.
I decided to kill two birds with one stone and swap the m . . .
There was really no problem. Just decided to buy an old 17" macbook pro and see what could be done with it. I wound up with an early 2008 from ebay - really cheap. It already had an SSD installed in place of the original HDD. I upgraded the RAM to the maximum of 6 GB and bought a 1 Tb HDD. You . . .
I had replaced the stock HDD on A1261 Macbook Pro 4,1 with an SSD. While this was better, I did not have enough storage. For that reason I installed a platter drive in the superdrive space and created a "Fusion Drive." Now I have 1.25 TB of storage that really screams.
It was easy, but I have experi . . .
He was having issues with his mac being very slow and was running an older OS.
I replaced the original 3.5 hdd with a 2.5 ssd and used a hdd adapter. I also installed an optical drive to hdd adapter sold by ifixit and placed a 500gb hdd here. The reason I swapped the two is on this iMac the optical d . . .
My old hhd was failing, so instead of just replacing it, I decided to upgrade to a fusion drive.
For best results with a fusion drive, the hhd should go in the optical drive enclosure and the ssd should go where the original hdd was. This meant using a 2.5" to 3.5" SATA adapter to hold the drive in . . .
