12.7 mm PATA Optical Bay PATA Hard Drive Enclosure
$24.99
$24.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
You can now have two hard drives in your laptop or Mac Mini! By replacing your optical drive, you can install up to a 320 GB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Optical Bay is 12.7 mm tall. Accepts 2.5 inch PATA hard drives up to 9.5 mm in height.
Note: This enclosure does not work with SATA drives or drives taller than 9.5mm.
Install Video
Compatibility
iBook G4 12" 1.33 GHz
iBook G4 12" 800 MHz-1.2 GHz
1 GHz
1.2 GHz
800 MHz
iBook G4 14" 1.42 GHz
iBook G4 14" 933 MHz-1.33 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
PowerBook G4 Aluminum 12" 1-1.5 GHz
1 GHz
1.33 GHz
1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 15" 1.67 GHz
(High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
(High-Res)
PowerBook G4 Titanium DVI
1 GHz
667 MHz
800 MHz
867 MHz
PowerBook G4 Titanium Onyx
550 MHz
667 MHz
Show 11 more devices
