12.7 mm PATA 8x SuperDrive
  • 12.7 mm PATA 8x SuperDrive
Not for sale
Not for Sale
Not for Sale
Product Details
Description
Description
Have you ever thought about what goes on when you slide a CD into your optical drive? The whirr of the spinning CD, the buzz of the lens assembly, the sweet music data pouring from the disk, and, of course, the laser—it's a rock concert for your computer internals.
But what about when your optical drive fails? No lasers, no spinning discs, no rock 'n' roll. The show is cancelled. However, a faulty optical drive doesn't need to be the end of the computer rock tour. By replacing the optical drive, you can get the show back on the road.
Like rock 'n' roll, this drive isn't for everybody and will only fit in 12.7 mm optical bays. It won't work in MacBooks or 15" MacBook Pros, which require a thinner drive. This SuperDrive also won't work in iMacs with Pioneer (DVR-K06RS), or in 14" G4 iBooks with TEAC (DV-W28SL) drives.
NOTE: Requires removing ribbon cable and bracket from your current optical drive for installation.
Drivers: No drivers required
Compatibility
iBook G4 12" 1.33 GHz
iBook G4 12" 800 MHz-1.2 GHz
1 GHz
1.2 GHz
800 MHz
iBook G4 14" 1.42 GHz
iBook G4 14" 933 MHz-1.33 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
iMac G5 17" Model A1058
1.6 GHz
1.8 GHz (EMC No. 1989)
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
Mac Mini Model A1176
1.5 GHz (Core Solo)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.33 GHz (Core 2 Duo)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
PowerBook G4 Aluminum 12" 1-1.5 GHz
1 GHz
1.33 GHz
1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 15" 1.67 GHz
(High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
(High-Res)
PowerBook G4 Titanium DVI
1 GHz
667 MHz
800 MHz
867 MHz
PowerBook G4 Titanium Onyx
550 MHz
667 MHz
Show 20 more devices
Customer Reviews
