From the pier in Alameda, the USS Hornet is imposing: a wall of grey steel that rises out of the water and just keeps going. At 872 feet, she’s more than 200 feet shorter than the US Navy’s newest carriers. A giant when she was built in 1943, she’s mid-sized at best today.
I was there for Instrumental’s Build Better Summit, a gathering of the people who decide how electronics get made. Those decisions are where a device’s repairability is won or lost, long before it lands on my bench. The talks ran in the cavernous hangar that once housed the ship’s air wing and, under the gaze of a decommissioned F-4 Phantom, centered on Instrumental’s niche: automating defect detection on the manufacturing line. It’s a fascinating and fiendishly complex task, and one that was running on AI a decade before anyone whispered the word “superintelligence” into dear leaders’ ears.
Between talks, I went exploring. Up close, the Hornet is showing her mileage. Cables run exposed where no self-respecting sailor would have tolerated them, and patched holes mark where equipment was cut out during decommissioning. Signs and props built for museum visitors sit beside fixtures built for war, a stark reminder of how thoroughly this floating arsenal has been defanged for the amusement of the general public.
Later, I ventured up to the flight deck. It was nearly empty: me, a couple of other attendees, and an FJ-2 Fury, the Navy’s take on the F-86 Sabre, parked on the same deck that welcomed the Apollo 11 crew home in 1969. Standing there in the bay wind, I wondered what it would feel like as a workplace rather than an exhibit.
What the Camera Sees
Instrumental builds AI vision inspection for electronics lines. Cameras photograph every unit as it’s assembled, and software flags anything that looks off, including defects nobody thought to look for.
The demo that stuck with me was a high density connector, the type you might find inside servers, with a couple of bent pins. A trained inspector would probably spot the defects; but I couldn’t see them at all, even after being told exactly where to look. It’s a slightly humbling admission for someone who takes things apart for a living.
The camera flagged them in a fraction of the time it would take a person. And people do miss things: in one of Instrumental’s case studies, a telecom customer found 4.6% of its units had been slipping past human inspectors entirely. Where AI is concerned, numbers like this have a ring of inevitability about them. I have very mixed feelings about that, as I know many of us do.
Two Ends of the Same Product
I spend my days at the other end of a product’s life. By the time a device lands on my bench, the factory’s choices are set in stone, or more often, set in glue. Some of them make my job harder: adhesive instead of screws, parts stacked so one won’t come out without another, cables routed for speed rather than access.
It would be a mistake to think those choices are made carelessly. Glue goes on faster than screws go in, and seconds per unit add up across millions of units. The people optimising a line are solving a real problem, and they’re very good at it.
What’s striking is how much the two worlds want the same thing. A bent pin caught on the line should be intercepted so it doesn’t become a dead port in a customer’s hands, or a repair ticket on someone’s bench. Inspection data maps exactly where assembly is fragile, and more often than not, that’s where repair is fragile too. If designers can see that map early, both ends of the product benefit.
That doesn’t mean I think manufacturing has its priorities right. Lines are optimised for efficiency and cost, and they’ll stay that way. But it’s increasingly clear that designing for the end of a product’s life, making devices people can open, service and keep running, is essential for the health of the planet. That adds complexity to production, and with it cost. The question shouldn’t be whether to optimise for cost at the expense of serviceability, but rather how to minimise the cost of repairable design.
The move towards repairable design is real, but it’s not a steady march. It’s two steps forward, one step back, and plenty of devices, wearables especially, have only become harder to fix. But where progress is made, it’s not happening by accident. It’s driven by years of pushing from fixers, repair shops, advocates and all of us here at iFixit, and lawmakers from US statehouses to the EU are finally listening. If you’ve ever bought a part, written a guide or signed a petition, you helped get us here. Smarter production will have a role to play in where it goes next.
Still Afloat
Walking back down the gangway, I looked again at the exposed cables and the scars where equipment used to be. Earlier I’d read them as neglect, but that’s not quite right. They’re the marks of a hard life at sea in wartime, and the wrinkles and creases of age. Each blemish is a character trait, each patched hole a story that’s probably lost to time.
The USS Hornet is still here, more than 80 years after she launched into a world engulfed by war, because people kept opening her up and fixing whatever broken thing they found inside: first out of necessity, later out of respect for her history. After all, nobody builds a carrier expecting her to come home unscarred. They build her so the scars can be mended.
It was fitting, then, to hear about the next generation of consumer tech from inside the belly of a beast built to resist entropy in one of the most hostile environments on Earth. Our gadgets don’t need to last 80 years. But they could stand to be built on the same assumption.
0 Comments
