MacBook Pro 15" Unibody (Mid 2009 to Mid 2012) SATA SuperDrive Cable
$29.95
$29.95
Product Details
Features
Features
Identified by 821-0826-A printed on the cable.
Note: this cable is for SATA optical drives only. If you do not have a Mid 2009 through Mid 2012 Unibody MacBook Pro 15", this part will not work in your machine.
Compatibility
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
MacBook Pro 15" Unibody Mid 2009
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
MacBook Pro 15" Unibody Mid 2010
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
Show 3 more devices
Related Stories
User avatar
My Problem
I had installed an OWC Data Doubler in my 2011 MBP and all was fine until the now-external SuperDrive stopped working properly. So I swapped the SuperDrive back into the MBP only it didn't work there either.
I put my HDD back in and THAT didn't work! Something was wrong. Careful inspection reveal . . .
User avatar
My Problem
I accidentally damaged the optical drive cable of Macbook pro 15" when I opened it. I am covered under apple support, but since this is a self-inflicted damage, I didn't expect Apple to replace it for free. I was forced to find the spare part myself which is when I found iFixit.
My Fix
I searched in iFixi . . .
User avatar
User avatar
User avatar
My Problem
I broke the super drive cable when I was installing the original hdd in place of the super drive. I bought a SSD to be my main hard drive. All was going well until the cable tore.
The cable sits in a 90 degree angle and when you pull out the super drive or put the hard drive enclosure down, it ca . . .
User avatar
My Problem
My secondary internal drive was no longer responding. I noticed that the SATA Super drive cable was broken
My Fix
I bought a part on iFixit and within 3 days I fixed it.
My Advice
Yeah, I fixit is a great resource. They got all the parts, plus STEP by STEP instructions on how to repair things on your own. No mor . . .
User avatar
My Problem
The Computer: Late 2011 MacBook Pro, 15.4"
The Problem: When I bought the computer, I immediately replaced the SuperDrive with a second hard drive. The Solid State was replaced the original HDD (in the hard drive section) and the original drive replaced the SuperDrive (i.e. CD Drive). All was . . .
User avatar
My Problem
I was replacing my optical drive with an SSD. In the process I somehow broke this fragile cable. It wasn't immediately obvious as the drive showed up correctly on the first boot, but stopped responding shortly afterwards. I first suspected the drive, but when I swapped the HD and the SSD, the troubl . . .
User avatar
My Problem
Before selling my early 2011 15" MacBook Pro I wanted to remove the OWC hard drive caddy and put back the SuperDrive. In the process I lost the SuperDrive cable.
My Fix
It was easy to reinstall the optical drive. I did learn not to use the screws that came with the optical drive caddy because they are too b . . .
