MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
$44.95
$44.95
Product Details
Features
Features
Unable to access your hard drive?
Then you might need to replace your hard drive cable!
Please read the option descriptions. Some options do not include the hard drive bracket.
Compatibility
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
Repair Stories
User avatar
My Problem
While installing a data doubler, I apparently cracked the OEM SATA Cable. iFixit got me the replacement part fairly quick and upon inspection, the replacement part was more robust than the OEM cable. MacBook Pro SATA cables are notorious for breaking when moving them because they are so thin and del . . .
User avatar
My Problem
The cable doesn't last -as you can see looking around for this MBP- probably because very small vibrations along the daily use of the computer. I think the cable breaks near the black screws used to attach ir to the chassis. If you disassemble the bottom case and get the drive out of its place leavi . . .
User avatar
User avatar
User avatar
My Problem
Erratic and slow performance with a 1 TB SSD after replacing the original HD which was also slow. When running the mid 2012 MBP 13 inch from the SSD via USB the computer ran fine.
My Fix
So ordered hard drive cable from ifixit and replaced the old one. Worked great. with the SSD it is about as fast as my wo . . .
User avatar
My Problem
My son's macbook pro was showing the blinking question mark folder when he turned it on. I tried to recover it through the disk utility, but the folder wasn't showing up. Apple support website suggest taking it to the apple store if you fail at this stage, but I chose not to. Instead I bought a S . . .
User avatar
My Problem
Initially I turned on the computer and a flashing folder file icon appeared, wouldn't boot up. After some research I replaced my hardrive with an ssd but it still would not boot up. I went on ifixit and read similar stories. I finally figured out that it was the cable that was defective.
My Fix
The part cam . . .
User avatar
My Problem
My MBP had been acting strange for a while until it one day just displayed a blinking folder with a question mark on boot. Initially i thought my hard drive was broken, but replacing it didn't solve my problem. After some online searches and trying different things, I realized it had to be the hard . . .
User avatar
My Problem
Had a missing hard drive in my MacBook Pro. Reading around online it sounded like the HDD cable needed replacing, so I grabbed one from iFixit
My Fix
Super easy repair. The supplied step by step instructions were perfect and easy to follow. The cable works perfectly
My Advice
Remember to unplug your battery before a . . .
User avatar
