Parts Mac iMac Intel 17"
Store
Don't know your model? ID Your Mac
Device Info
iMac Intel 17"
Arctic Silver Thermal Paste
3.5 gram Arctic Silver thermal paste tube. Thermal paste forms a continuous, conductive layer between a processor and its heat sink, improving cooling performance and kee...
$8.99
iMac Service Wedge / New
iMac Service Wedge
Foam support wedge for holding heavy computers in place.
$12.99
Arctic Silver ArctiClean
Two part thermal paste remover. Two part cleaner used to dissolve thermal paste and purify the surfaces of heat sinks and processors before applying new thermal paste. In...
$7.99
250 GB SSD / Part Only
250 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 275 GB Unformatted
$114.99 – $129.99
500 GB SSD / Part Only
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
$164.99 – $179.99
1 TB 7200 RPM 3.5" Hard Drive
Replace or upgrade the hard drive in your compatible iMac with this part.
$59.99
1 TB SSD / Part Only
1 TB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 1050 GB Unformatted
$309.99 – $324.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
PC2-5300 2 GB RAM Chip
Replacement or upgrade RAM chip. Specs: 2 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz. This speed upgrade will make your computer faster. Compatible with Core 2 Duo Ma...
$14.99
PC2-5300 4 GB RAM Chip
Replacement or upgrade RAM chip. Specs: 4 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz. This speed upgrade will make your computer faster. Compatible with Core 2 Duo Ma...
$74.99
Showing products 1 - 10 of 32
Device Info
The 17" Intel iMac features internal optimization for better performance, and later versions (the 2 and 2.16 GHz) increased processing speed and Core 2 Duo chips.
Need more memory? Two PC2-5300 1GB RAM chips will max out your memory at 2 GB.
Select your model above for parts and assistance!
