Introduction
Describe what you will do.
Tools
No tools required.
Parts
No parts required.
  1. Unlock the lock latch on the left.
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
  3. Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
    • Locate the RAM card in its slot.
    • Spread the leaf springs that hold the memory module in place (left and right).
    • Remove the memory module (RAM) from its connector.
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,412 Reputation
149 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 35
