Introduction
Describe what you will do.
Tools
No tools required.
Parts
No parts required.
Unlock the lock latch on the left. Unlock the lock latch on the right. Remove the battery while holding the lock latch unlocked.
  • Unlock the lock latch on the left.
  • Unlock the lock latch on the right.
  • Remove the battery while holding the lock latch unlocked.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover. Lift the bottom right cover with the iFixit Opening Tool. Lift the lower left cover with the iFixit Opening Tool.
  • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
  • Lift the bottom right cover with the iFixit Opening Tool.
  • Lift the lower left cover with the iFixit Opening Tool.
  • Finally clear the bottom cover completely to access the main components.
Locate the RAM card in its slot. Spread the leaf springs that hold the memory module in place (left and right). Remove the memory module (RAM) from its connector.
  • Locate the RAM card in its slot.
  • Spread the leaf springs that hold the memory module in place (left and right).
  • Remove the memory module (RAM) from its connector.
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
338 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
