Tools
No tools required.
Parts
No parts required.
Unlock the lock latch on the left. Unlock the lock latch on the right. Remove the battery while holding the lock latch unlocked.
  • Unlock the lock latch on the left.
  • Unlock the lock latch on the right.
  • Remove the battery while holding the lock latch unlocked.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover. Lift the bottom right cover with the iFixit Opening Tool. Lift the lower left cover with the iFixit Opening Tool.
  • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
  • Lift the bottom right cover with the iFixit Opening Tool.
  • Lift the lower left cover with the iFixit Opening Tool.
  • Finally clear the bottom cover completely to access the main components.
Using the Phillips screwdriver, unscrew the 4 screws holding the processor cooling radiator. Remove the cooling radiator. Once the radiator removed you can see the processor with its locking latch. Now unlock the processor with a small screwdriver. Then remove it gently.
  • Using the Phillips screwdriver, unscrew the 4 screws holding the processor cooling radiator.
  • Remove the cooling radiator. Once the radiator removed you can see the processor with its locking latch.
  • Now unlock the processor with a small screwdriver. Then remove it gently.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
315 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 27
