Tools
No tools required.
Parts
No parts required.
Unlock the lock latch on the left. Unlock the lock latch on the right. Remove the battery while holding the lock latch unlocked.
  • Unlock the lock latch on the left.
  • Unlock the lock latch on the right.
  • Remove the battery while holding the lock latch unlocked.
Start by locating the two screw caps on the left side of the screen. Remove the lower screw cover. Then the top screw cover.
  • Start by locating the two screw caps on the left side of the screen.
  • Remove the lower screw cover.
  • Then the top screw cover.
Locate and then remove the first center screw on the top of the screen frame. Then the second central cap on the top of the screen frame. Then locate and remove the screw cap on the upper right side of the screen frame.
  • Locate and then remove the first center screw on the top of the screen frame.
  • Then the second central cap on the top of the screen frame.
  • Then locate and remove the screw cap on the upper right side of the screen frame.
Then finally the bottom right screw cap of the screen frame. Then unscrew the screws behind the screw caps, starting with the one at the bottom left of the frame. Then at the top left.
  • Then finally the bottom right screw cap of the screen frame.
  • Then unscrew the screws behind the screw caps, starting with the one at the bottom left of the frame.
  • Then at the top left.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Then the first central screw on the top edge of the frame. Then the second central screw on the top edge of the frame. Then the one in the upper right corner of the frame.
  • Then the first central screw on the top edge of the frame.
  • Then the second central screw on the top edge of the frame.
  • Then the one in the upper right corner of the frame.
And finally the one on the lower right side of the frame. Then gently use your nails. To remove the frame from the LCD screen.
  • And finally the one on the lower right side of the frame.
  • Then gently use your nails.
  • To remove the frame from the LCD screen.
Unscrew the screws on the front of the LCD screen. Next, unscrew the screws on the right side of the LCD screen, starting with the first one. Then the second.
  • Unscrew the screws on the front of the LCD screen.
  • Next, unscrew the screws on the right side of the LCD screen, starting with the first one.
  • Then the second.
Then the third. And finally the fourth. Repeat these operations then on the left side of the screen starting with the first screw.
  • Then the third.
  • And finally the fourth.
  • Repeat these operations then on the left side of the screen starting with the first screw.
Then the second. Then the third. . And finally the fourth
  • Then the second.
  • Then the third. .
Then flip the LCD screen. Then appears the connector to which is attached the connection cable of the LCD. Then peel off the tape covering the connector.
  • Then flip the LCD screen.
  • Then appears the connector to which is attached the connection cable of the LCD.
  • Then peel off the tape covering the connector.
then remove the cable from its connector. Once the cable is disconnected you can release the LCD screen. Once the cable is disconnected you can release the LCD screen.
  • then remove the cable from its connector.
  • Once the cable is disconnected you can release the LCD screen.
to reassemble your device follow these instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
338 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
