Tools
No tools required.
Parts
No parts required.
Unlock the lock latch on the left. Unlock the lock latch on the right. Remove the battery while holding the lock latch unlocked.
  • Unlock the lock latch on the left.
  • Unlock the lock latch on the right.
  • Remove the battery while holding the lock latch unlocked.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover. Lift the bottom right cover with the iFixit Opening Tool. Lift the lower left cover with the iFixit Opening Tool.
  • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
  • Lift the bottom right cover with the iFixit Opening Tool.
  • Lift the lower left cover with the iFixit Opening Tool.
  • Finally clear the bottom cover completely to access the main components.
Locate the screw that secures the CD / DVD drive. With the Philips screwdriver unscrew this one. Finally remove the CD / DVD drive from its location.
  • Locate the screw that secures the CD / DVD drive. With the Philips screwdriver unscrew this one.
  • Finally remove the CD / DVD drive from its location.
TO REASSEMBLE YOUR DEVICE FOLLOW THESE INSTRUCTION IN REVERSE ORDER.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
324 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 16
