Tools
No tools required.
Parts
No parts required.
Unlock the lock latch on the left.
  • Unlock the lock latch on the left.
  • Unlock the lock latch on the right.
  • Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
  • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
  • Lift the bottom right cover with the iFixit Opening Tool.
  • Lift the lower left cover with the iFixit Opening Tool.
  • Finally clear the bottom cover completely to access the main components.
  • Locate the hard drive with its plastic tab.
  • Remove the HDD from its SATA port using the plastic tab
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,352 Reputation
149 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 36
