Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Locate the M.2 SSD in its slot.
Unscrew the fastening screw of the latter.
Lift and remove the SSD M.2 drive from its connector.
Locate the hard drive in its location.
Lift it slightly.
Finally remove it from its SATA connector.
To reassemble your device, follow the instructions in reverse order.
Lift it gently and take it out of its place.
Carefully unplug the MAIN and AUX antennas.
Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
Find and separate the spring blades that maintain the memory module in place (right).
Find and separate the spring blades that maintain the memory module in place (left).
Remove the memory module (RAM) from its connector.
Remove the power cable from the fan.
Unscrew the two screws securing the fan.
Finally remove the fan and place it on your worktop.
Unscrew the circled screws in green and red
Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
Lift the keyboard
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
