Parts
No parts required.
Start by unlocking the right locking latch. Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  • Start by unlocking the right locking latch.
  • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card. Then, remove it and put it on your workplan.
  • Begin by spotting the dummy memory card.
  • Then, remove it and put it on your workplan.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Locate the 15 screws that hold the bottom cover of the device in place. Unscrew them and place them on your work surface. Then, un-clip the bottom cover, starting with the side shown in the third picture.
  • Locate the 15 screws that hold the bottom cover of the device in place.
  • Unscrew them and place them on your work surface.
  • Then, un-clip the bottom cover, starting with the side shown in the third picture.
Locate the hard drive in its location. Lift it slightly. Finally remove it from its SATA connector.
  • Locate the hard drive in its location.
  • Lift it slightly.
  • Finally remove it from its SATA connector.
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
324 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 69
