Parts
No parts required.
Start by unlocking the right locking latch. Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  • Start by unlocking the right locking latch.
  • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card. Then, remove it and put it on your workplan.
  • Begin by spotting the dummy memory card.
  • Then, remove it and put it on your workplan.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the 15 screws that hold the bottom cover of the device in place. Unscrew them and place them on your work surface. Then, un-clip the bottom cover, starting with the side shown in the third picture.
  • Locate the 15 screws that hold the bottom cover of the device in place.
  • Unscrew them and place them on your work surface.
  • Then, un-clip the bottom cover, starting with the side shown in the third picture.
Find and separate the spring blades that maintain the memory module in place (right). Find and separate the spring blades that maintain the memory module in place (left). Remove the memory module (RAM) from its connector.
  • Find and separate the spring blades that maintain the memory module in place (right).
  • Find and separate the spring blades that maintain the memory module in place (left).
  • Remove the memory module (RAM) from its connector.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
338 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 96
