1. Start by unlocking the right locking latch.
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. Unscrew the circled screws in green and red
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
    • Disconnect the connector circled in red in the direction of the arrow
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
    • Unscrew the screw circled in red
    • Pull out the M.2 SSD in the direction of the red arrows
    • Remove the screw circled in red
    • Lift up the hard drive
    • Remove the hard drive in the direction of the red arrows
    • Disconnect the two connectors marked in green
    • Remove the WLAN card
    • Press down on the two brackets boxed in red
    • Remove the RAM stick in the direction of the red arrows
    • Press with a screwdriver in the red circled area to spread the base of the battery
    • Remove the battery by holding the screwdriver
    • Remove the two screw circled in red
    • Disconnect the connector boxed in green in the direction of the green arrow
    • Remove the fan by lifting it up
    • Lift the retaining flap off of the connector boxed in red.
    • Disconnect the connector boxed in red.
    • Lift the flap that holds the connector (framed in green)
    • Disconnect the connector (framed in green)
    • Disconnect the connector marked in red by lifting it up
    • Disconnect the connector marked in green by pulling it in the direction of green arrows
    • Disconnect the connector marked in red by pulling it in the direction of the red arrows
    • Lift the black retaining flap that holds the connector marked in green
    • Unscrew the five screws circled in green
    • Lift the motherboard by taking it by the radiator as in the second picture
    • Lift the retaining flap that holds the connector marked in red
    • Lift the retaining flap that holds the connector framed in green
    • Remove the motherboard from the case.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,550 Reputation
150 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 191
