Parts
No parts required.
Start by unlocking the right locking latch. Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  • Start by unlocking the right locking latch.
  • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card. Then, remove it and put it on your workplan.
  • Begin by spotting the dummy memory card.
  • Then, remove it and put it on your workplan.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the 15 screws that hold the bottom cover of the device in place. Unscrew them and place them on your work surface. Then, un-clip the bottom cover, starting with the side shown in the third picture.
  • Locate the 15 screws that hold the bottom cover of the device in place.
  • Unscrew them and place them on your work surface.
  • Then, un-clip the bottom cover, starting with the side shown in the third picture.
Press with a screwdriver in the red circled area to spread the base of the battery Remove the battery by holding the screwdriver
  • Press with a screwdriver in the red circled area to spread the base of the battery
  • Remove the battery by holding the screwdriver
To reassemble your device follow the following instructions in reverse order
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
338 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 22
