This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! N131WU/BU/ZU Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
54
All Time:
842
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
    1. why! N131WU/BU/ZU Keyboard Replacement, Keyboard Screws: step 1, image 1 of 1
      • Remove the two keyboard retaining screws.
      Ask FixBot
    2. why! N131WU/BU/ZU Keyboard Replacement, Unclip the Keyboard: step 2, image 1 of 3 why! N131WU/BU/ZU Keyboard Replacement, Unclip the Keyboard: step 2, image 2 of 3 why! N131WU/BU/ZU Keyboard Replacement, Unclip the Keyboard: step 2, image 3 of 3
      • Insert a small screwdriver into the holes the screws were removed from in the previous step to unclip the keyboard.
      Ask FixBot
    3. why! N131WU/BU/ZU Keyboard Replacement, Disconnect the Cables: step 3, image 1 of 3 why! N131WU/BU/ZU Keyboard Replacement, Disconnect the Cables: step 3, image 2 of 3 why! N131WU/BU/ZU Keyboard Replacement, Disconnect the Cables: step 3, image 3 of 3
      • Using a plastic spudger, flip up the retaining latch on the ZIF connector securing the blue ribbon cable, then slide the cable straight out from the connector.
      • To release the orange flex cable, use the tip of a spudger to slide the latches on either side in the direction indicated by the arrows, then pull the cable straight out from the connector.
      Ask FixBot
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 842
