This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide shows how to remove and replace the battery of a why! N131WU/BU/ZU laptop after accessing it. Turn off and unplug the computer before removing the five screws and disconnecting the battery.
Parts
Tools
Remove the frame screws (red).
Remove the two keyboard screws (green).
Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
(Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
(Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
After these are removed, you can now remove the lower part of the case from the rest of the computer.
Remove the five Phillips screws securing the battery.
Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
Unplug the white connector: pry up to gradually move the connector
Peel off the adhesive foam holding the battery
To reinstall the replacement battery: use double-sided tape
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
1 Guide Comment
Merci beaucoup, tutoriel très bien fait qui nous a beaucoup aidé !
