This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
why! N131WU RAM Replacement
  1. why! N131WU RAM Replacement, Remove the Screws: step 1, image 1 of 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU RAM Replacement, Remove the Keyboard: step 2, image 1 of 3 why! N131WU RAM Replacement, Remove the Keyboard: step 2, image 2 of 3 why! N131WU RAM Replacement, Remove the Keyboard: step 2, image 3 of 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU RAM Replacement, Remove Keyboard Connections: step 3, image 1 of 3 why! N131WU RAM Replacement, Remove Keyboard Connections: step 3, image 2 of 3 why! N131WU RAM Replacement, Remove Keyboard Connections: step 3, image 3 of 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU RAM Replacement, Remove the upper screws: step 4, image 1 of 2 why! N131WU RAM Replacement, Remove the upper screws: step 4, image 2 of 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU RAM Replacement, RAM (Memory): step 5, image 1 of 3 why! N131WU RAM Replacement, RAM (Memory): step 5, image 2 of 3 why! N131WU RAM Replacement, RAM (Memory): step 5, image 3 of 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
To reassemble your laptop, just follow the instructions in reverse.
Special thanks to these translators:
fr en
75%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
30,731 Reputation
261 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 379
