Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
English
French
Translating step 24
Step 24
Lift the logic board EMI shield from the edge nearest the top of the iPad. Peel the EMI shield up from the logic board. This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
  • Lift the logic board EMI shield from the edge nearest the top of the iPad.
  • Peel the EMI shield up from the logic board.
  • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
  • Remove the logic board EMI shield.
Soulevez le blindage du côté le plus proche de la partie supérieure de l'iPad.
Décollez le blindage électromagnétique de la carte mère.
Vous devrez forcer un peu en raison des nombreux minuscules clips de fixation et le blindage risque de se déformer. Ce n'est pas grave. Essayez de minimiser la déformation. Il s'aplatira de nouveau quand il sera remonté et revissé.
Ôtez le blindage électromagnétique de la carte mère.
