Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
English
French
Translating step 27
Step 27
While supporting the display assembly, remove the following three Phillips screws over the display cable bracket. 2.4 mm Phillips screw 1.2 mm Phillips screw
  • While supporting the display assembly, remove the following three Phillips screws over the display cable bracket.
  • 2.4 mm Phillips screw
  • 1.2 mm Phillips screw
  • Remove the display cable bracket.
Tout en soutenant l'écran, retirez les trois vis cruciformes suivantes de cache de la nappe d'écran.
Deux vis cruciformes de 2,4 mm
Une vis cruciforme de 1,2 mm
Retirez le cache de la nappe d'écran.
