Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
English
French
Translating step 18
Step 18
Use an iOpener to heat the bottom of the iPad. Insert the blade of a halberd spudger to the left of the opening pick  on the bottom right corner of the iPad. Slide the halberd spudger along the lower edge of the iPad stopping  short about 1 centimeter before reaching the home button.
  • Use an iOpener to heat the bottom of the iPad.
  • Insert the blade of a halberd spudger to the left of the opening pick on the bottom right corner of the iPad.
  • Slide the halberd spudger along the lower edge of the iPad stopping short about 1 centimeter before reaching the home button.
Utilisez un iOpener pour chauffer le fond de l'iPad.
Insérez la lame d'une spatule hallebarde (halberd spudger) à gauche du médiator dans le coin inférieur droit de l'iPad.
Faites glisser la lame le long du bord inférieur de l'iPad et arrêtez à environ 1 centimètre avant d'atteindre le bouton home.
