Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
English
French
Translating step 12
Step 12
If necessary, reheat your iOpener and lay it over the top edge of the device. Wait a couple minutes for the adhesive to soften before reinserting the blade of the halberd spudger. Insert the blade of the halberd spudger just past the front-facing camera, on the opposite side of the opening pick. Continue to slide the blade of the halberd spudger to the upper right corner of the iPad.
  • If necessary, reheat your iOpener and lay it over the top edge of the device. Wait a couple minutes for the adhesive to soften before reinserting the blade of the halberd spudger.
  • Insert the blade of the halberd spudger just past the front-facing camera, on the opposite side of the opening pick.
  • Continue to slide the blade of the halberd spudger to the upper right corner of the iPad.
Si nécessaire, réchauffez votre iOpener et placez-le sur le bord supérieur de l'appareil. Attendez quelques minutes que l'adhésif ramollisse avant de réinsérer la lame de la spatule hallebarde (halberd spudger).
Insérez la lame de la spatule juste après la caméra frontale, du côté opposé du médiator.
Continuez à faire glisser la lame de la spatule jusqu'au coin supérieur droit de l'iPad.
