Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
English
French
Translating step 8
Step 8
Lay a hot iOpener along the upper left corner of the iPad, spanning from the opening pick to the front-facing camera. After letting the adhesive soften, insert the blade of your halberd spudger into the iPad above the opening pick. Cut the adhesive along the upper left side of the iPad towards the front-facing camera using the halberd spudger. This may require reheating the edge of the iPad.
  • Lay a hot iOpener along the upper left corner of the iPad, spanning from the opening pick to the front-facing camera.
  • After letting the adhesive soften, insert the blade of your halberd spudger into the iPad above the opening pick.
  • Cut the adhesive along the upper left side of the iPad towards the front-facing camera using the halberd spudger. This may require reheating the edge of the iPad.
Placez un iOpener chaud le long du coin supérieur gauche de l'iPad, depuis le médiator jusqu'à la caméra frontale.
Après avoir laissé l'adhésif ramollir, insérez la lame de votre spatule hallebarde (halberd spudger) dans l'iPad, au-dessus du médiator.
Coupez l'adhésif le long du côté supérieur gauche de l'iPad, vers la caméra frontale, à l'aide de la saptule. Cela peut nécessiter de réchauffer le bord de l'iPad.
