Fix Your Stuff
Right to Repair
Parts & Tools
Notice: You are editing a prerequisite guide. Any changes you make will affect all 10 guides that include this step.
English
French
Translating step 6
Step 6
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case. Pull first at one corner, then the other. Pull to the side—not up.
  • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
  • Pull first at one corner, then the other.
  • Pull to the side—not up.
  • This can require a lot of force.
Poussez fermement le boîtier inférieur vers l'avant du MacBook (en l'éloignant de la charnière) pour séparer le dernier des clips qui fixent le boîtier.
Tirez d'abord un coin, puis l'autre.
Tirez sur le côté, pas vers le haut.
Cela peut nécessiter de forcer un peu.
