Fix Your Stuff
Right to Repair
Store
Notice: You are editing a prerequisite guide. Any changes you make will affect all 10 guides that include this step.
English
French
Translating step 5
Step 5
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes. Give the pick a firm twist to pop free the third clip securing the lower case to the chassis. Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
  • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
  • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Insérez à nouveau votre médiator sous le bord avant du boîtier inférieur, à côté de l'un des deux trous de vis du milieu.
Faites fermement pivoter le médiator pour ouvrir le troisième clip qui maintient le boîtier inférieur et le châssis.
Répétez la manipulation à côté de l'autre trou pour défaire le quatrième clip.
