Fix Your Stuff
Right to Repair
Parts & Tools
Notice: You are editing a prerequisite guide. Any changes you make will affect all 10 guides that include this step.
English
French
Translating step 3
Step 3
Insert one corner of an opening pick into the space between the lower case and the chassis. Slide the opening pick around the nearest corner and halfway up the side of the case. This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
Separate the clips
  • Insert one corner of an opening pick into the space between the lower case and the chassis.
  • Slide the opening pick around the nearest corner and halfway up the side of the case.
  • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
Insérez le coin d'un médiator dans l'espace créé entre le boîtier et le châssis.
Faites glisser le médiator le long du bord le plus proche, puis de la première moitié du côté du boîtier.
Ceci permet d'ouvrir le premier des clips cachés qui fixent le boîtier inférieur au châssis. Vous devriez sentir et entendre le clic du clip qui s'ouvre.
[title] Separate the clips
[* black] Insert one corner of an opening pick into the space between the lower case and the chassis.
[* black] Slide the opening pick around the nearest corner and halfway up the side of the case.
[* icon_note] This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
