Fix Your Stuff
Right to Repair
Parts & Tools
English
French
Translating step 8
Step 8
Peel the tape off the cable connected to the back of the LCD screen and unplug the cable which is connected to the bottom. The screen should now be fully removed from the laptop casing. Peel the tape off the cable connected to the back of the LCD screen and unplug the cable which is connected to the bottom. The screen should now be fully removed from the laptop casing. Peel the tape off the cable connected to the back of the LCD screen and unplug the cable which is connected to the bottom. The screen should now be fully removed from the laptop casing.
  • Peel the tape off the cable connected to the back of the LCD screen and unplug the cable which is connected to the bottom. The screen should now be fully removed from the laptop casing.
Retirez l’adhésif du câble branché à l’arrière de l’écran et débranchez le câble connecté au bas de l’écran. L’écran devrait être maintenant complètement retiré du boitier de l’ordinateur portable.
