Introduction
Change all the buttons including joy sticks for a PlayStation 3 controller.
Dual Shock 3 Play Station Controller. Dual Shock 3 Play Station Controller.
  • Dual Shock 3 Play Station Controller.
First you will take a little philips screw driver and remove the 5 screws from the back cover.
  • First you will take a little philips screw driver and remove the 5 screws from the back cover.
Make sure you have all your tools and pieces.
  • Make sure you have all your tools and pieces.
Then you will lift the battery to unscrew the motherboard from the front cover, by squeezing the prongs inward (circled in red) and pulling up.
  • Then you will lift the battery to unscrew the motherboard from the front cover, by squeezing the prongs inward (circled in red) and pulling up.
Now that the battery is off you can remove the screw holding the mother board down.
  • Now that the battery is off you can remove the screw holding the mother board down.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Next you will unclip these prongs on the motors (circled in red). Do this for both motors. Next you will unclip these prongs on the motors (circled in red). Do this for both motors.
  • Next you will unclip these prongs on the motors (circled in red). Do this for both motors.
My start button no longer works. How would I fix that?
Dalton Vander Weide - Reply
Then you just lift the motherboard and control panel. It will come off giving you access to the front buttons.
  • Then you just lift the motherboard and control panel. It will come off giving you access to the front buttons.
Next your joy sticks just pop off and the new ones pop back on.
  • Next your joy sticks just pop off and the new ones pop back on.
Then lifting these pads will give you access to the four front buttons (circled in yellow), and D-pad (circled in red). Then lifting these pads will give you access to the four front buttons (circled in yellow), and D-pad (circled in red).
  • Then lifting these pads will give you access to the four front buttons (circled in yellow), and D-pad (circled in red).
The D-pad and buttons just slide right in place of the old ones.
  • The D-pad and buttons just slide right in place of the old ones.
Then you clip that control panel and motherboard back in the same way it came out. Then you clip that control panel and motherboard back in the same way it came out.
  • Then you clip that control panel and motherboard back in the same way it came out.
Don`t forget to insert the screw (circled in red) holding the motherboard to the control panel.
  • Don`t forget to insert the screw (circled in red) holding the motherboard to the control panel.
Your trigger buttons slide out, and the new ones slide in. The bottom L2 and R2 buttons have a little bar that clicks in, and out of he holder as well (circled in yellow). Your trigger buttons slide out, and the new ones slide in. The bottom L2 and R2 buttons have a little bar that clicks in, and out of he holder as well (circled in yellow). Your trigger buttons slide out, and the new ones slide in. The bottom L2 and R2 buttons have a little bar that clicks in, and out of he holder as well (circled in yellow).
  • Your trigger buttons slide out, and the new ones slide in. The bottom L2 and R2 buttons have a little bar that clicks in, and out of he holder as well (circled in yellow).
Clip your battery back on.
  • Clip your battery back on.
Clip the back of the case back on and screw the 5 screws back in and you're done. Clip the back of the case back on and screw the 5 screws back in and you're done. Clip the back of the case back on and screw the 5 screws back in and you're done.
  • Clip the back of the case back on and screw the 5 screws back in and you're done.
18 other people completed this guide.
wyatt
781 Reputation
1 Guide authored
Vegas Room H9 Member of Vegas Room H9
Community
6 Members
10 Guides authored
Past 24 Hours: 9
Past 7 Days: 69
Past 30 Days: 361
All Time: 16,065
