Introduction
A common error with the iTeufel Air is the defect of the 5V power pack for the power supply of the main board. This can be recognized by the fact that the iTeufel Air's standby LED no longer lights up. Normally, when the iTeufel Air is plugged in, the standby LED should light up orange. The cause of the defect in the 5V power supply is a defective diode (P6KE 200A) on the circuit board, which leads to failure of the power supply.
Note: These instructions are intended for specialists with electrical engineering experience.
If you are not a specialist, a repair in a repair cafe or similar is recommended! The repair involves working on the main board, which has potentially lethal voltages of 230 V!
Open the iTeufel Air by prying open the speaker cover on both sides with a pry tool so that the cover detaches from the rest. It is recommended to use the plastic lifter at the points marked in red and carefully lift the cover 2-3 cm so that the adhesive strips detach from the cover.
If the cover doesn't come off with a plastic pry bar, you can gently try it with a small flathead screwdriver
If you have loosened the cover on one side, fix the cover so that it remains open, e.g. with the plastic lifter and loosen the cover on the other side as well.
Now unscrew the circuit board of the power supply with a PH 2 screwdriver.
Before you remove the circuit board, disconnect the circuit board connector for the power supply (black cable) and the white circuit board connector to the main circuit board.
The defective diode is marked with the red circle. Replace this with a soldering iron for an identical diode (P6KE 200A) and pay attention to the polarity of the new diode when installing
A defective diode is not always visually recognizable. If so, the diode should be unsoldered and checked using the diode test mode of a multimeter.
If the diode is functional, other components of the 5V power supply may also be defective.
In the event of overvoltage damage (e.g. lightning strike), the following components can be defective: fuse (5mm grid), IC switching power supply (TNY 280 PN) and the bridge rectifier (on the back of the circuit board). These all need to be replaced.
Work the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
4 Comments
Vielen Dank für die sehr visuelle Reparier-Anleitung, ist super gemacht!!
Da mein iTeufel auch nicht mehr funktioniert, werde ich der Anleitung folgen, habe aber folgende Fragen. Ihr schreibt: Bei einem Überspannungsschaden (z.B. Blitzeinschlag) können folgende Komponenten defekt sein: Sicherung (5mm Raster), IC Schaltnetzteil (TNY 280 PN) und der Brückengleichrichter (auf der Rückseite der Platine).
Ich habe leider keine elektronischen Vorkenntnisse, traue mir zwar zu, die Komponente aus- und wieder einzulöten, aber ich weiss nicht, wie ich die korrekten Komponenten bestelle. Die Diode P6KE 200A und das Schaltnetzteil TNY 280 PN sind einfach, sie haben dankenswerterweise technische Codierung, existieren solche Codierungen auch für die Sicherung (5mm Raster) und den "Brückengleichrichter".? Dazu noch die Frage, was ist der 1000uF cap, der von @faxmodem erwähnt wird? Ist das die Sicherung? Habe mal "Sicherung 5mm Raster" in einem Elektronik-shop eingegeben, da gibt es 43 verschiedene Referenzen ;)
Danke.
Daniel
