iRobot Roomba i6 Battery Replacement
  1. iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: step 1, image 1 of 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: step 1, image 2 of 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: step 1, image 3 of 3
    • Using your PH2 size screwdriver, remove the edge sweeping brush.
    • Using your PH2 size screwdriver, remove the 5 screws highlighted in the 2nd picture.
    • These top two screws highlighted in orange will unscrew completely if you keep going so be sure to stop unscrewing them as soon as you feel resistance.
    • Lift the bottom cover straight up off of the Roomba from the two spots the arrows are pointing to.
  2. iRobot Roomba i6 Battery Replacement, Remove the Battery: step 2, image 1 of 1
    • Push the highlighted tab up while lifting the battery out of the Roomba.
    • During re-assembly, you just have to align the battery and push down until the tab clicks.
To install the new battery, follow these instructions in reverse order.
Kaden Gonzalez
230 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 114
