This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Is your Roomba no longer charging?
If the battery isn't the problem, the transistor shown is likely to blame. While replacement charging stations don't cost much, the transistor only costs a few cents.
Replacement: BDP948 ... available everywhere
Video Overview
On this device, the replacement battery is quite new.
The charging dock is flashing green.
Check if the Roomba charges with a bench power supply:
You need 19.4 V DC at about 1.25 A. Pay attention to the correct connection of the + and - socket.
When connecting, the voltage drops to 13.6 V - the voltage of the battery - and the maximum charging current of about 600 mA flows. This is proof that the power supply is charging, but the charging dock is no longer doing so.
Disassemble the charging dock until you can access the circuit boards. One of these is the switching power supply, and one controls the charging process.
Switching power supply
Charging board
One of the transistors on the charging board is significantly discolored; this is likely the cause. You can desolder it and test it with a transistor tester, for example.
The original PNP transistor STN790A is not very easy to find; a BDP948 is a suitable replacement transistor. It is rated for 45 V, up to 3 A, and has the same housing (SOT223), so it should fit.
The transistor must be soldered well and sit flat so that it can dissipate its heat.
Without the Roomba connected, there is 2.87 V at the contacts. When the Roomba is connected, the transistor switches and the voltage rises to 13.4 V - the replacement battery is being charged again.
Follow these steps in reverse order to reassemble your device.
