iRobot Roomba 880 Battery Replacement
  1. iRobot Roomba 880 Battery Replacement, Battery: step 1, image 1 of 2 iRobot Roomba 880 Battery Replacement, Battery: step 1, image 2 of 2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: step 2, image 1 of 1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: step 3, image 1 of 2 iRobot Roomba 880 Battery Replacement: step 3, image 2 of 2
    • Remove the battery using the green tabs on either side of the battery.
Frances Belcher
420 Reputation
2 Guides authored
Cal Poly, Team S17-G4, Banghart Spring 2017 Member of Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Members
5 Guides authored
One Comment
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 4,600
