Introduction
The springs in the wheel are very important to moving the Roomba, if they happen to break or become bad they could get in the way of the movement of the Roomba. This guide is relatively complicated and does require that you take inventory of every screw that is pulled out.
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
Remove the Roomba's external underside.
Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
Carefully remove the spring from the component assembly as shown
4 Comments
My spring has fallen out and you don’t show where the spring attatches
The bracket for the front (white and black) wheel broke. Where can I get a new one?
