Introduction
Use this guide to replace your Shuffle's battery. Replacing the battery requires a fine-tipped soldering iron and knowledge of surface-mount soldering.
Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
Remove the plastic cover and set it aside.
Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
Pull the logic board assembly out of the outer case.
Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board.
Flip the battery upwards to reveal the solder pads soldered to the logic board.
Desolder the battery from the logic board by heating up the solder joint with a soldering iron and simultaneously using a pair of tweezers to pull the battery wire away from the logic board.
If you have never soldered before, we have a guide that makes it easy.
