iPod Nano 2nd Generation Bottom Bezel Bracket Replacement
  1. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement, Bottom Bezel: step 1, image 1 of 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: step 2, image 1 of 1
    • When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  3. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement, Bottom Bezel Bracket: step 3, image 1 of 1
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #00 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
  4. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: step 4, image 1 of 1
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
  5. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: step 5, image 1 of 1
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
  6. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: step 6, image 1 of 1
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack.
  7. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: step 7, image 1 of 1
    • Lift the bottom bezel bracket out of the iPod.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 17,701
