Fix Your Stuff
Right to Repair
Store
Introduction
With up to 15 steps, the laminating process of iPhone X OLED screen is much more complicated than LCD screen of previous iPhone versions. Official maintenance cost of broken screen is also up to $279. After several attempts, REWA LAB is honored to present you our hard-earned success with iPhone X screen refurbishing.
Video Overview
  1. Run function test – Display; Touch; 3D Touch and Swipe-up. All going well.
    • Run function test – Display; Touch; 3D Touch and Swipe-up. All going well.
  2. Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner. Cut out the top bracket with Cutting Nipper. Then separate bezel from the screen with Cutting Nipper.
    • Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner.
    • Cut out the top bracket with Cutting Nipper. Then separate bezel from the screen with Cutting Nipper.
    • Be careful with flex cables when removing bezel in the flex cable area.
    • Once done, test the screen again. Run function test – Display; Touch; 3D Touch and Swipe-up. All going well. By now, the most difficult step during iPhone X screen refurbishing has been completed.
  3. Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with Cutting Wire. Test again after separating. All going well.
    • Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with Cutting Wire. Test again after separating. All going well.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Glue removing for iPhone X screen can be applied with hand tearing.
    • Glue removing for iPhone X screen can be applied with hand tearing.
  6. Embed the OCA rubber block aligning mold into the base. Then place the OCA rubber block into the corresponding position of the mold. Place OCA into the corresponding position of the OCA aligning mold.
    • Embed the OCA rubber block aligning mold into the base. Then place the OCA rubber block into the corresponding position of the mold. Place OCA into the corresponding position of the OCA aligning mold.
    • After that, embed the OCA aligning mold into the base and apply pressure to fit the OCA against the rubber block.
    • Prepare a new glass lens and place the new glass lens into the glass lens mold. Embed the glass lens mold into the base.
    • Place the whole mold into the laminating machine and press “OCA laminating” button.
  7. Place the OLED assembly into the OLED mold. Place the OLED rubber block and embed the OLED mold into the base. Apply pressure to fit the OLED with the rubber block.
    • Place the OLED assembly into the OLED mold. Place the OLED rubber block and embed the OLED mold into the base. Apply pressure to fit the OLED with the rubber block.
    • Then place the OCA laminated glass lens into the glass lens mold and embed the glass lens mold into the base.
    • After that, place the whole mold into the laminating machine. Press “LCD laminating” button.
  8. Put the screen into Bubble Removing Machine for 15 minutes. Once finished, take out the screen.
    • Put the screen into Bubble Removing Machine for 15 minutes. Once finished, take out the screen.
  9. Prepare a new iPhone X bezel. Apply B7000 glue evenly on bezel and back of the screen. Then press them against each other and leave to rest for 10 minutes.
    • Prepare a new iPhone X bezel. Apply B7000 glue evenly on bezel and back of the screen. Then press them against each other and leave to rest for 10 minutes.
  10. Run function test – Display; Touch; 3D Touch and Swipe-up. All going well.
Phryne
10,251 Reputation
80 Guides authored
0 Comments
Past 24 Hours: 19
Past 7 Days: 281
Past 30 Days: 1,148
All Time: 2,529
