This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
使用本指南来带代替你破碎的屏幕iPhone SE。它会告诉你如何删除主页按钮,前置摄像头和传感器组件,耳机喇叭,液晶板都将需要转移到你更换前面板。如果你已经拥有的那些部分更换屏幕,follow this much shorter guide instead.
在任何情况下,重要的是传递的'original”按钮到新的显示为Touch ID(指纹扫描)功能。
这部分也与iPhone 5s兼容。
你也可以使用本指南来代替以下部分:'''
如果你的手机显示屏碎了,请避免屏幕碎裂更加严重,可以通过使用透明胶粘贴屏幕来避免屏幕的主体损坏。
把透明胶带贴在iPhone手机显示屏上,尽可能的覆盖整个屏幕。
一只手固定好iPhone机身,另一只手轻轻地把机身从前面板底端的home键上分离。
当你左手使用吸盘拉动的时候,右手用塑料撬棒在后机壳边缘处,轻轻地撬动,使屏幕和机身分离。
稍微打开屏幕,可以看到盖住home键电线的挡板铁片就可以了。
只有手机原装的Home键组件才能使用Touch ID功能。如果你扯断这根电线,装上新的home键只能恢复home键功能,而将失去Touch ID功能。
使用手机撬棒推动松下铁片,再用镊子取下来。
一旦连接器被撬开了后,把home键底端从机身上拉起,把手机顶端当做一个转动支点。
把显示屏立起来,保持跟机身成90度角。在你维修手机的过程中一直保持这个状态。
用橡皮筋把显示屏如图三所示固定住。这会避免在维修过程中显示屏电缆的损坏。
Tool used on this step:iOpener$19.99
使用一个 iOpener 来软化胶带来安全移除。我们的iOpener使用步骤 可以教你用。
将您的设备,遵循这些指示,以相反的顺序。
120 other people completed this guide.
Special thanks to these translators:
75%
These translators are helping us fix the world! Want to contribute?
Start translating ›
7 Comments
Have issues after a couple days. I replaced the screen according to instructions and started up well. Screen started having issues and within a few minutes screen showed likes and faded to black.
This will be the screen that you have purchased, or due to a faulty repair…Not due to the guide.
Hi, thanks in advance for your support! I managed to detach the digitizer from the LCD after a small drop, thus I bought a replacement screen from ifixit… unfortunately resulting in a very bad quality aftermarket piece. Dimmed luminosity, changes in temperature(color), and affected by polarized glass, which I wear. I already reclaimed this to Ifixit and I`m waiting for support, but I thought to pick up my broken original display and glue back the digitizer, is that possible, or is this shown in any guide here around??
Thanks again!
STEPS 9-12 need a re-working - Re-assembly instructions should be put just under the disassembly instructions so that when you scroll back up the page, you’re re-assembling in step order ;)
