Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only, battery removed.
  1. Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
    • Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
  2. Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board. Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  3. Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly. Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
  4. Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  5. Lift and remove the vibrator out of the iPhone.
    • Lift and remove the vibrator out of the iPhone.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 128
