Introduction
Prereq only for removing power button.
Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
One 2.1 mm Phillips #00 screw
One 1.7 mm Phillips #00 screw
Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
